Overheating-97 GT
Overheating-97 GT
Started having problems when i replaced the broken thermostat. The car started overheating but it wasn't showing on the dashboard themp gague.
So i took the thermostat off this morning and ran the car around the block. the car still overheadted but the temp gague didn't show it.
The coolant spews out of the radiator cap. My guess is that my radiator is clogged.....since there is no thermostat.
Can anyone give me some ideas on what it is or could be.
P.S.
There are traces of oil in the coolant system due to a broken intake gasket i fixed a couple weeks ago.
P.S.
IS your radiator clogged? Old/rusty? if you fixed the thermostat, I would inspect that next. (that is if you are sure its not the thermostat) also, I would look into possibly figuring out why your temp gauge isnt working.
S.O.F.B.
So i replaced the radiator cap with a new one and coolant still spewed from the f*&#ing cap. Whats next a restriction in the radiator preventing coolant from entering the engine block thus causing the coolant to spew out the cap?
I wish i had a drive way so i can just take it all apart and clean it throughly and confirm the problem myself.
OH but the temp gague IS working now that i replaced the cap. I'm puzzled.
Is the temp gauge reading at 0? The temp gauge is not a dummy gauge and will work properly, if the car warms up and the gauge rises to normal operating temps and stays in there I would imagine the car is NOT overheating. Since you replaced the cap and it still is doing it I would check the neck that the cap screwes on, with age a few people expereince cracked expansion tanks due to the plastic design.
I appreciate all of your guys' input. Today i found out i was running without motor oil. So i put three quarts and it drove better. by that i mean there was less vapor coming from the cap and temp gague was lower than before. I'm guessing it helped keep the engine cooler. anyway i discovered a small,very tiny spot where air bubbles were coming out; below the thermo-housing where it connects to the intake. :/
