Grinding going into 2nd gear
ok so i just got my car GT today, and i had to drive 150 miles from the dealership home, so i had some times to play with the car, everything worked great and she looks good and drives really nice compared to my 00 V6, my only problem was and i must not have noticed it when i test drove it was when going from 1st to 2nd gear, while throwing it into 2nd the gear grinds, even when im at a stop and put it into 2nd it sometimes does it, i don't know what the clutch setup is but i assume it would be stock but i can't be certain, what kind of issue would cause this, also the car does not grind at all while in gear whatsoever, and 2nd is the only gear it grinds going into, thanks for all the help i really appreciate it!
How much free play does the clutch pedal have? It should be 1" to 1¼" when you press on it with your hand, before you feel the TOB start to compress the clutch spring--if it is more than that then the clutch may not be fully disengaging, and dragging, and causing the gear clashing.
Here is a good article about using the OEM semi-automatic adjuster, including a method for manually improving the adjustment...
It should not be doing that, and it will not get better all by itself--how much free play is in the pedal?
One other issue is that the there is a TSB (04-15-6) recommending that the transmission fluid amount be reduced to 3.2qt from the original 3.8qt specification. Though this generally manifests itself as a 2-3 gear issue.
It is wise, if current status is unknown, to drain the transmission and refill it with 3.2qt.
I (and Tremec, the transmission manufacturer) recommend Mobil 1 ATF:
i went and checked and pressed on the clutch pedal and i didn't have to press hardly at all to feel the cable pressure, if that was what you wanted me to check, when i have the car off i can go through 2nd gear without any grinding, idk if that would tell u anything, im not going to drive the car in the winter anyways but i just wanted to know what this might be thanks
ok idk if this tells u anything but i started the car, when i put it in second (no gas car was idling) it grinded, i held the clutch in still and put the shifter in nuetral, then put it in second again, and no grinding, did this several times and nothing, it was fine, does that tell u anything?!
ok I'm affraid this is most likely a synchronizer issue, as this seems to be the case on a lot of T-3650 transmissions witch i wish i would have know 24 hours ago before i got the car, but i am going to take it to a ford dealer sometime this week and talk to a service manager to see what repairs might cost, im assuming 1-1.5k with labor and parts possibly higher, i drove the car today and it did it every time, although if i double clutched, it wouldn't grind going into 2nd gear, so idk if that helps, but looks like im SOL on this one
