removing catalytic converters
#23
The catalytic converters "light off", I.e start doing their job of converting unburned hydrocarbons and carbon monoxide to CO2, at 400 to 600°F; they normally operate at 1200 to 1600°F--and can, if there's a lot of unburned fuel, reach 2000°F. This is why they have heat shields, sometimes insulated.
There are stories of people parking their cars in tall dry grass, and having the cat(s) ignite a fire--I have never directly observed this, nor I have never heard from a reliable source of this happening.
As to having/not-having cats it makes no practical difference in engine power as a properly sized converter presents very little restriction.
One last comment, back pressure is always bad--the less you have the more power you will make at any rpm. Here are a couple of white-paper documents that try to dispel the "backpressure myth".
Backpressure Myth
Backpressure Myth II
Backpressure Myth
#24
Backpressure Myth
Backpressure Myth II[/QUOTE]
After reading the articles I guess thats why with a wide open exhaust you feel like you lose power on the bottom end/take off bc it performs better in the upper rpm range with the less backpressure you have.
Backpressure Myth
#26
#27
It's the lower exhaust gas velocity, in the larger pipe at lower engine speeds, that robs the power as it does a worse job of pulling the gases behind it along for the ride, and assisting in clearing the cylinder and pulling in the fresh charge.
The key point to remember is that each pulse of exhaust gas has mass (weight) and is being "fired" out of the engine--it is expanding gas in a closed chamber with one way out, the "bullet" is the high pressure leading edge of the pulse.
#29
Did he go from the stock pipe to the after market? If so then there's the difference. There is also a significant placebo effect from the added noise...
#30
