Engine Break-in Oil???
About to put my engine back in my Mustang. Is there any special oil or oil type I should use for the breaking in of it? Like the other day I saw some Royal Purple Break-in oil. Good? I've also been told to use 5w30 non synthetic oil just to break-in and then use synthetic. And I've also heard to just use 5w30 synthetic. Any suggestions? Thanks
And what were some of your guys methods of breaking in your engines when reinstalled?
Use Dino oil,5w30 is fine and cycle the engine thru the entire rpm range. Take it up to about 4500 rpm and run it for a bit,then down to 3000 then 2200 and so on. Do not run at steady rpm for too long. It has to cycle thru the powerband to properly seat everything. Do it for about 500 miles. Short trips at first to heat cycle everything. You are gonna notice some oil consumption but this is normal til it's broken in. Change oil out after about 5 or 6 hundred miles to remove any metal particles and change filter. Then Dino oil again to 1500 then add AMSOIL for a long life
Ok. Cool. thanks for the imput. Anyone else with a good breakin method and oil prefrence. Like when i first start it how high should i rev it and for how long. then how about driving it around to break it in. how fast or what rpm ranges? The book has a breakin method but i'd like to hear someother methods. thanks
I am installling the motor tomarrow and want to get it running as soon as possible so can someone plz give me some detail of they're break-in oil and breakin method. I know there are a bunch of guys that installed new short blocks or rebuilt their own motors. Thanks
