Belt sits funny on SC pulley
Hey all,
I noticed that my Vortech head unit looks like it is slightly angled and the belt is about 1/8th to 1/4 in. off the pulley. It seems to be fine on the other pullies, but I was curious if it should ride centered or if this is normal on the SC pullies. Has anyone had this issue and did you shim the head unit to get it perp to the engine? Any help is appreciated.
Thanks
Thanks
It sounds like the belt is jumping ribs because of the angle of the supercharger, this is not normal and the belt should right on the pulley like any other accessory. You may have to shim the mounting bracket so the blower sits proper, you can probably do it with a few washers I have meet alot of people at car shows and what not that have had the same problem and the washers did the trick.
Thanks
