strange strut started leaking - which struts to get
Old 02-13-2011, 12:09 PM
cisurfer
cisurfer's Avatar
Default strange strut started leaking - which struts to get
My setup is QA1 K member and A-arms, upr coilover kit with 14" 175lbs spring, MM CC plates and 99-04 strange 10 way struts. I just installed fox body strange 10 way shocks out back last week. My passenger side strut sprung a leak and it pissin oil all over my brake caliper and coilover and wheel. Now when I go over bumps with the passenger side the steering wheel shimmys violently and the car wants to move all over the road. The strut is def blown. I love the way strange struts perform but damn they are so annoying when pair up with CC plates. People say its the coil over kit making noise but I had this "clunk" noise before the CO kit with just CC plates. I have also heard of going with fox body struts when lowered because they are shorter and wont bottom out (causing leaks). Should I suck it up and go with the fox body struts strange, or should I switch companies and go with another brand that wont give me a headache? I love the adjustability of going from a 90/10 style strut for drag to a hard cornering setting when put on number 10.
cisurfer is offline
Old 02-13-2011, 01:34 PM
lizzyfan
Underboss
lizzyfan's Avatar
I'm happy with the KYB AGX's
lizzyfan is offline
Old 02-13-2011, 03:27 PM
cisurfer
cisurfer's Avatar
Are they good for drag racing? Running coil overs with them?
cisurfer is offline
Old 02-13-2011, 05:16 PM
cisurfer
cisurfer's Avatar
I think since Im not going to get away from the "strange clank" due to my recent installed rear shocks I mind as well go with the front struts again for the fox body because although they make tons of noise paired with CC plates, i heard it is rare for them to leak, they are amazing struts because I can get that lakewood 90/10 feel on "1" and turn the dial to "9-10" and get that bilstein stiffness.
cisurfer is offline
Old 02-13-2011, 07:36 PM
03greyGT
03greyGT's Avatar
I ran Strange 10 ways front and rear...and the fronts drove me crazy enough that I took them off a few weeks after I put them on...Im running Tokico 5-way drag struts and Mach/Bullitt Tokicos in the rear now...no noise and no problems... I drag the car too..
03greyGT is offline
Old 02-13-2011, 08:57 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
^+1, I bought a set of Strange shocks--they should have come with a tube of K-Y, or at least Vaseline--worst damned shock I ever owned...
cliffyk is offline
Old 02-13-2011, 10:24 PM
cisurfer
cisurfer's Avatar
When you say tokico drag struts. You mean illuminas?
cisurfer is offline
drfister
05-03-2018 10:38 PM
chrisdbassplayer
09-01-2015 05:30 PM
GimpyHSHS
08-29-2015 06:30 PM
inyadreems
08-21-2015 09:10 AM
01moostanggt
08-17-2015 01:22 PM
Quick Reply: strange strut started leaking - which struts to get
