How much oil does your horse burn?
#21
I always thought these days with synthetic oil you could just leave the oil in longer if you don't put the 4k - 5k miles on the motor.
Maybe it's just me thinking that....
#22
I have no clue I just drain the **** and put more oil in haha. Theres still a lot of oil in the heads even though the pan bolt is off so I think its a little far-fetched to think you have an accurate measurement based on oil draining of how much is being burned.
#23
goose egg. its funny that you bring up burnt oil, our company truck is a 97 F150 i hopped in the other day and the oil light starts flashing and pressure gauge starts goin crazy, i pull over and check the oil it was 5.5 quarts low!!! i couldnt believe this thing was running. i took it to our shop and put 4 quarts in it and the dipstick was dry as a bone. ran to the store and got some more oil and ended up needing almost 2 more qts lol
#24
You can, however I would not let it go past 6 months--the nasties that build up in the oil (especially in vehicles that never see 1 to 2 hours at speed at least once a month) will continue to eat away at your engine while it's just sitting there...
#26
...00..Gt..Not a drop...I am over 100,000 miles .....5-30 dino oil and a Motocraft filter. Summer driver only. My 98 F-150 is my work truck.....210,000 miles with the same 4.6. Maybe will use a third of a quart in 3000 miles. I change it at 2500 miles in the winter cause I idle it more. Stuff looks like driveway sealer draining out of the pan.
