Why?!?! Please help me!
So I installed a Bama custom tune on my car. I gotta say the tune worked great. But now I'm having cooling issues. I called them and they said it shouldn't have anything to do with the tuner; So I'm asking here.
I installed a mishimoto 14 in electric fan yesterday.. All day yesterday the fan would come on when it was supposed to. No I'm all the way to the "L" in Normal, and the fan won't kick on. I can trick it into starting as long as I turn on the A/C but otherwise it wont come on.
What's going on with my car?
Also once it got to that level, even turning on the A/C, which turns on the fan, wouldn't bring it down. The fan is a one speed unit, and I have it wired to turn on when the "low speed fan" is supposed to kick on.
I'm so fed up with it, I wanna rip it apart. Please help.
Edit: coolant levels are up to par, and I'm assuming the relays are good, since the fan turns on with the A/C.
You have the it wired wrong. I'm not sure how you wired this fan but the factory harness has 3 wires, low speed, high speed, and a ground. If you're fan is kicking on when you turn the ac on that means you ONLY have the high speed wired (if u spliced into the factory wirring of course). The stock mustang fan ONLY operates on high when the engine is hot AND the ac is turned on. I have a flex a lite slimboy on mine and when I wired it I simple connected the power wire of the flexalite onto the low speed power wire of the stock fan, connected the ground, and left the high speed wire tapped off and disconnected.
Thats exactly what I did. I spliced into the red wire, rather than the orange/blue wire. Like I said the fan was working perfectly fine yesterday and this morning. When I installed the tune is when these problems started happening. Could it be that the thermostat for the fan burnt out?
And maybe all those sources were wrong, I personally don't know; but I've been told by more than one person that the high will come on without the A/C but at a different temperature. The A/C coming on kicks the fan on at any temp. Even through the low speed wire.
I don't know why, but the first time I went back to stock it didn't fix the problem. I re-installed and still nothing.
I let the car sit for about 30 minutes while I was on here bitching. When I got frustrated and decided to return to stock yet again, just in case. Low and behold PEFRFECTION! the fan cut on right when it was supposed to. I installed the tune, and yet again it worked like a charm. My car is running perfect again.
Thank you all. I'm still wondering what the hell happened, but glad its working.
If your problem just magically is working and not working sounds like a bad connection.
Well after reinstalling the tune, I played with the temp settings for the fan. I now have it set for the Low Speed at 200, and the high speed at the highest setting. I think since I dont have anything connected to the high speed it was trying to turn something on that wasnt there. Hence the over heating.
