Bolt-Ons..4.6lt 2v
#21
well the speedcal is used to recalibrate your speedometer after a gear install because when you change gears, it also changes your speedometer reading (this problem could be fixed through a hand held tuner if you dont already have one, or buying the speed re calibrator). the 8.8 rear gear pinion bearing is only for the 2010+ mustangs with the 8.8 rear end because ford changed the inner rear gear pinion bearing in those vehicles. the install kit is usually recommended for cars with 60k+ miles because it comes with new seals and gaskets. plus, why not do it all at once with the rebuild kit if you already have the gears out and everything. it just seems like a good investment to protect the new gears you would be installing
#24
yea i was reading up on installing the gears i can prob do it but i am going to just let the pros handle it and my girlfriends cousin runs Mtuning here in town and he said he can play around with it on the dyno and get a nice tune for me...So now i just gotta order parts.....
Going out to Orlando Speed World Tonight To See What She Does Before I Start The Mods..Wish me luck..
