Do I need Spring Isolators with Lowering Springs?
Old 08-26-2005, 12:30 AM
4ZZS
4ZZS's Avatar
Default Do I need Spring Isolators with Lowering Springs?
I am looking to buy either the Eibach Pro-Kit or the Steeda Sport Springs for a 2002 GT Convertible.
Most places also offer/suggest that I get Polyurethane Spring Isolators (donuts). What are they supposed to do and are they necessary?
Any comments appreciated before I make my purchase.
Who's got the best price on springs?
Thanks.
4ZZS is offline
Old 08-26-2005, 12:52 AM
Aixtreme89
Aixtreme89's Avatar
Default RE: Do I need Spring Isolators with Lowering Springs?
I have the pro-kit in my car. I used the stock spring isolators, I just took them off the stock springs. I believe they are there to prevent squeeking everytime your suspension moves. I think its worth the centimeter to avoid the annoying squeeking.
Aixtreme89 is offline
Old 08-26-2005, 01:09 AM
josh_0351
josh_0351's Avatar
I would not buy em, as you can definitely re-use your stock isolators (I have an 2002 also and was able to reuse mine). If for some odd reason yours are all torn to ****, I still would not pay the $30+ for new ones – just head to your local auto parts store and buy a foot or so of 1” radiator hose and cut it into 4 equal sections (about 4" long each) and slide it over your springs. (Problem solved for less than five bones).
josh_0351 is offline
Old 08-26-2005, 02:57 AM
Shawn02GT
Shawn02GT's Avatar
it depends on your mileage, but with an 02 you should be fine with the stock ones.
Shawn02GT is offline
Old 08-26-2005, 03:49 AM
4ZZS
4ZZS's Avatar
Thank you guys! My car is in pretty good shape, with less than 30K miles, so I'll likely be able to use the originals.
Time to order.
4ZZS is offline
Old 08-26-2005, 03:09 PM
josh_0351
josh_0351's Avatar
ORIGINAL: 4ZZS
Time to order.
Good luck - install is a breeze! Don’t forget that it will probably take up to a week for your springs to fully settle, so don’t fret if there doesn’t appear to be a difference immediately after slapping em on….
Old 08-26-2005, 03:19 PM
Emann0007
Emann0007's Avatar
I bought them, course I had 80K miles on the car....
Emann0007 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
lincolnshibuya
07-05-2020 03:05 AM
CS2007
06-25-2019 09:45 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Do I need Spring Isolators with Lowering Springs?
