CC plates and sturt removed
Old 03-14-2011, 08:53 PM
stanglvr38
stanglvr38's Avatar
Default CC plates and sturt removed
So I undid my stock cc plates and I let the strut tower drop with a jack under the a arm. I put it back together and tightened up the bolts. Now, do I need an alignment?
I didn't put in any new springs or anything like that. I just undid the bolts to see how the suspension on this car works.
stanglvr38 is offline
Old 03-14-2011, 09:08 PM
945LSTANG
945LSTANG's Avatar
What do you mean by "undoing" your CC plates? Did you just remove the upper strut nut?
945LSTANG is offline
Old 03-14-2011, 09:27 PM
stanglvr38
stanglvr38's Avatar
I undid the 3 bolts on top of it.
Old 03-15-2011, 09:36 AM
school boy
school boy's Avatar
might be a good idea to get the alignment checked. next time, just remove the strut nut instead of the cc bolts
school boy is offline
Old 03-15-2011, 01:52 PM
stanglvr38
stanglvr38's Avatar
So what are the chances of it being off? Can I drive it for like 200 miles w/o an alignment?Where is the strut nut?
Old 03-15-2011, 01:59 PM
BraMas
BraMas's Avatar
if it was the factory C/C plates there should have been a pop rivet in them it that is still there the plates probably did not move
BraMas is offline
Old 03-15-2011, 03:21 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
This ^^^
After recently installing new CC plates and seeing how crappy the stock plates were I would highly recommend new ones.
WannaBeGearHead is offline
Old 03-15-2011, 05:21 PM
ALSANT99
ALSANT99's Avatar
I read that better cc plates are needed when you lower your car,but if you don`t lower your car and want better cc plates with new struts will the cc plates still be a good idea?
ALSANT99 is offline
Old 03-15-2011, 07:58 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The stock plates were designed to meet two goals:
  • minimise NVH at the expense of precise control;
  • be cheap to manufacture;
They meet both criteria nicely, so if you want something of higher build quality and offering more precise handling (at the expense of more noise, vibration and harshness) then get a set of quality after market 4-bolt plates.
I have Steeda's and am very pleased with them, most of the 4-bolt sets are very good...
cliffyk is offline
Old 03-15-2011, 09:10 PM
945LSTANG
945LSTANG's Avatar
This.
Quick Reply: CC plates and sturt removed
