abs dash light!
abs dash light!
if i were to take the abs bulb out of the gauge pod would that cut power off to other bulbs?
do the bulbs run off a curcuit or are they independent of one another?
i swaped my engine out for a different generation motor and my abs system light turned on i was told to pop the bulb, i just took it out completely should i actually pop the bulb and plug it back in or just keep it out as i did..
my car is a 97 i swapped in a 02 engine so the abs systems aren't alike.. since the computer and all electronics were swapped and i left the old brake system my abs is shut down..
so the light turned on instead of putting in like 2000 dollars just to upgrade...
[GeezerRant]
ABS and traction control are similar in that they were specifically designed to accommodate driver's that don't know how to control braking or acceleration. If you know how to perform a panic stop without locking up the wheels you don't need ABS, and as most of us here know traction control is just an annoyance.
I've only had ABS on a couple cars (and I lived in New England for 45 years so I know about snow and ice), and the only time it ever kicked in was once when I got a new Mercedes E300 and took it to a mall parking lot on a snowy Sunday morning to see what it did.
Drive defensively, don't tailgate, anticipate what is unfolding in front of you, and learn how to stop without locking up the brakes; and you'll never need ABS...
[/GeezerRant]
[/GeezerRant]
exactly!!! i may be young but i'd call myself an excellent driver.. with out abs i still do a 175 to 0 stop with out locking up... lol
