throttle bodies and plenum combos
hey guys ive decided to look into a throttle body and plenum upgrade. any suggestions on the size i should change to? 70mm or bigger? i do plan later on getting a supercharger (if that matters). also is it benificial to do an upgraded plunum too?
From what i hear the plenum is more of a restriction than the throttle body. I don't know if that's true, but that's what i've heard.
Since you will be doing a blower down the road i'd definitely do a 75mm or possibly a 78mm.
The plenum is the weak link; in fact the stock 65mm TB, combined with most any after market plenum, will outflow a 75mm TB on the stock plenum.
Also if you are running n/a there is no need for a TB larger than 70mm. Larger units will hurt charge velocity at WOT and high rpms, not really enough to matter however they will not add anything either.
More about all this here...
The Accufab is very pretty, but pricey and will not outperform any other on an n/a 2V engine, as they just don't need any more than 475 cfm.
I have the Pro Products plenum and 70mm TB, and turned 262/305 rwHP/torque with modest bolt-ons and a tweaked tune.
Spend more if you like...
