New tranny What kind?
So i pulled my tranny tonght and noticed the case was cracked and also when i pulled plug to drain fluid chunks of metal fell out so im pretty sure its toast. My question is what should i put back in? Just a rebuilt T3650 which was in there or something different.
I would like to put a better trans in but not sure what all would entail in doing so
Thanks
Thanks
Well if you have a T3650 in there now you can put in another one or buy a built one. It you keep the same trans it is just a matter of dropping your current trans and putting in the new one.
If you found metal shavings in the fluid I wouldn't bother putting it back in.
I dont see it on their site yet, but supposedly gforce transmissions has put out a 3650 that will hold up to 1000hp. Someone else also offers a 600hp version i believe, it might be promotion. If your looking for the easiest way to put in a trans to hold more power i would look into these options.
i found this rebuilt tranny on smartpartsauto.com for 1100. I like the price but im not sure because of how much lower it is than every other web site i have looked at. Does anyone know if they are a reputable web site and would the tranny be of good quality?
Heres the web site-http://www.smartpartsauto.com/manual...0_mustang.html
Thanks
Thanks
What all will i need to purchase to swap to the t56? i would like to swap to that but wont i need a new drive shaft and clutch? Also does the bell housing bolt up as well or will i need adapters?
lizzyfan i read that link and its great but doesent say anything about if my old clutch for the t3650 will work or not. sxynerd said i would need new clutch but that thread never said anything about it. Also wondering if the cobra bellhousing bolts right up?
i have a AODE for a 94-98 4.6 and a 2000 4.6 witch will fit a 99-04 both built by wolford trans. the 2000 stall will go with $1,300. I was going to convert my t56 over and had some trouble with the pats system. The dealers around here have not a clue. if interested call 270 7341964 Eric
treesloth
09-28-2015 07:03 AM
mrappe
09-26-2015 10:16 AM
