Where to tune..
Where to tune..
Just got 31 spline axles differential and 3.73 gears installed, need to get my speedometer in tune Do I need a shop with a dyno? Thanks!
Also, if anyone would happen to know if they sell convertible tops where the glass is already attached, or do all kits come disassembled. Thanks again!
You need a speed cal or you have to get different speedo gears for the trans to fix your problem.
The tops are a 2 piece design. The top itself and the piece that has the window in it. The window piece is attached first and than the top is put on over it
Cant find the little gears right now. Latemodel resto did not have them for a manual trans for some reason anymore. But here is a speed cal
http://www.americanmuscle.com/ford-s...tool-9410.html
I found the little gears for the tranny, 17 bucks. Im a car newb as BraMas knows, so dont mind my stupidness...the money spent on a speedo recal tool, could also be used for a decent tuner for my car that would do the same thing? It has a POS hypertech one right now, change when fan goes on, rev limit, an i forget what the other thing was.
I just recently changed my stock gears to 4.10's and I purchased both the speedometer gear and the speedcal. Installed my speedometer gear but was having problems with the speedcal after I installed it so I took it off until I can find someone to install it for me. Purchased the speedcal from american muscle for $199.99, bramas gave you the link. And I purchased the speedometer gear from steeda autosports for $16.75. Here's the link.
http://www.steeda.com/store/steeda-s...d-mustang.html
And yes, you are correct, you cannot change the speedometer with a tuner on the 96-98 mustangs.
