Power Mods for a Noobie
#21
What I'm worried about is this drone I keep reading about. I found some Super 44's for $74 each and was going to have them put in place of the stock one's at 2.25".
I asked the guys at the muffler shop if I needed an x-pipe or h-pipe right away to get a nice sound and they all said not really.
But now I'm reading about this drone and I hear if you don't had certain tubes, catbacks, or chambered tips that you'll go crazy on the highway driving above 2000rpm.
What I want to do is build a best bang for your buck, $500 or less installed exhaust plan for bad a$$ sound without any of this infamous drone on the highway.
#23
OP for the moment it sounds like a quality supercharger build is out of your price range slightly. Nitrous is going to be your best bet to meet your power "goals" but to me n20 just isnt that fun. It leaves your car a dog outside of pushing a button that makes you blast off for a few seconds. This coupled with having to keep the bottle refilled and warm to me makes it more of a task and hassle than fun for a street car, in my opinion. But keep this in mind, it costs a lot more to get to 350-380RWHP N/A than it does getting 400RWHP+ F/I(supercharger, nitrous, turbo).
Wellllll....recoil, bullet speed, bullet trajectory, stopping power, mass(weight) of bullet, expansion and accuracy. You asked :P .
It is my understanding that twin-screw kits are significantly more in-depth. I have not installed a Centri, I have however installed a KB. The fact that you have to disassemble, re-organize and reinstall the entire top end of the motor makes it not so simple. As far as I know you just bolt the centri up to its pulley, do some piping, injectors, MAF and you're good to go. Might have to tap the oil pan depending on manufacturer and model.
Yep the KB kit is very complete. All you need is tools and spark plugs.
+1
Whipple doesnt make a blower for this engine. At least the stock intake manifold. I believe youd have to buy the $2,000+ tork tek intake manifold to make it work.
keep in mind, some kits dont include any sort of tune... so if you dont have a tune, thats like another 500-1000$ for a tune... kenne bell includes a safe base "chip" tune.
not tryin to push KB, but its probably the most complete kit there is... i think the ONLY thing it doesnt have is spark plugs lol..
if you want quick fast cheap easy HP... i say NOS. only problem is you gotta find a place to get the juice from, and keep it full. but for 500$, and probably like 100-200$ labor (hell, you could probably do at that in your garage, easy as a throttle body swap if you do a small plate kit)... honestly, i think this would have been my first mod ever if i had the knowledge i do now. if i get a 240sx or a BMW i'm def doing as big a shot as it can handle safely. you just gotta make sure that you have the bottle open (extra $ for the auto bottle opener) before you wanna use it..
#24
Why a midpipe over new mufflers? I'm wanting a nice aggressive sound out of my mustang, with a couple hp as a bonus to the mod. I was thinking about flowmaster super 44's. But I was just going to have my local muffler shop cut out the stock mufflers and weld in the flowmasters?
Is a midpipe better than my idea? If so...why?
#25
Two things and two things only. Gears and then exhaust.
Gears: 4.30's for the street and curve or 4.10's for the strip. If you run out of RPM's, change your tire height.
Exhaust: Flowmasters for power and sound or SLP's or similar for wet diaper farts.
Then read until you're not a Noob anymore.
#26
because thats where the HP is at in our cars exhaust, the midpipe/headers. and since an aftermarke midpipe is only $150-170 its a pretty good bang for the buck mod. Mufflers wont add bu maybe 1-2 hp whereas a good X/H pipe will add that good muscle car sound and about 10-15hp
#27
There is a difference in adding boost or engine mods to make more power and freeing up Hp by making your air pump run more efficiently. By adding a better flowing exhaust system it puts less pressure on your engine and therefore will actually prolong your Stock bottom end. You may actually see a slight drop in boost across the entire power band but you will NOT loose any power because of it.
The only way I would start to worry is if your tune is on the fence and has an erratic A/F at high RPM's. ...but I would have worried about that well before adding an O/R H.
#28
#29
I might have. I went WOT on Friday coming home from work and either my MAF pegged or fuel pressure gave out because something happened and I lost all power and bucked a little bit. Scared the **** out of me. It sounds like a friggin dump truck i'll tell you that, i'm actually really surprised. I've heard a few LT setups that are about this loud. Hopefully without sounding like an old man i'm considering taking the O/R H off, I can't hear my blower anymore and i cant decide what I like more.
#30
keep in mind that the midpipes that are in the 150 to 180 range dont have any cats and you will have to swap in the factory pipe for inspections. id go with the gears and programmer option from am. muscle if i were you. im actually gettin ready to order it myself.
