led turn signals
i just replaced all my brake lights, and turn signal bulbs to led bulbs...
i also replaced the stock flasher with a 5 pin led flasher.. everything works fine and flashed correctly, the problem is that with the headlights off and i click on the turn signals the odometer flashes also.. its kinda random... the only way the odometer stays on is if i turn the headlights on... why is that???? |
i looked at the stock flasher and it looks like a 6 pin relay.. it has the 5 regular sized pins and one small pin... i cant find a 6 pin led flasher relay... any one know why im having the problem listed above..??
