are these rear brake pads
Last time I ordered Pads I got a mix up order and they sent me a box of the SAME pads. So I either have 2 sets for the front or 2 sets for the back. I just dont know and the box does not say. Can you tell by looking? I think they are rear because i dont remember the fronts having that spring hinge think at the top.
The Wearever gold kit has the rear set listed as having TWO pads with top springs.... I might have a full set in this case..
http://shop.advanceautoparts.com/web...641422125____#
http://shop.advanceautoparts.com/web...641048835____#
ok so i have 4 pads like the one on the top and 4 pads like the one of the bottom (in my pic) I am pretty sure this is a full set then. excellent, cause this is a 74$ set.
For the rear calipers the pistons don't push back in, they need to be screwed back in which either required a special tool or you can do it with a pair of needle nose pliers. Make sure the notches are verticle (12 oclock and 6 oclock) when its finished.
