thermostat question
They put the 195s in for a cleaner running engine. The hotter they run the cleaner they run. They will get a tiny bit better MPGs too. I always liked the 180s for my old hot rods. The last time I looked for a 180 I couldn't even find one.
You can find 180 degree t-stats at any local auto parts store.
The stock thermostat opens between 192°F and 199°F, and is fully open at 219°F.
from the '03 shop manual"
This means that the target controlled engine temperature is 210°F give or take a few. The fan ON and OFF and a few other fan parameters in the tune need to be tweaked to take full advantage of the lower temp t-stat.
I run a 180°F thermostat¹ which is obviously is 20°F cooler than stock. This lets me run a bit more aggressive timing.
¹ - After market thermostats are typically rated by the target control temperature--their opening and fully open temperatures are rarely available.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
