Fuel system options.
Well here we are, currently im sitting on 42# injs and a 155lph walbro in stock tank with a return style 97 system. Starting to get my ducks in a row for a new engine/blower combination and needless to say I'm going to need a fuel system to support 650ish rwhp. I only want to do this one time. What kind of options am I looking at, could I go with a weld in sump and elimator pump from aeromotive and be done? Any better options?
None of this is intended as a solution, just a FWIW look at where you are...
At 40psi the 42lb/h injectors will be pretty much tapped out (95% duty cycle) by 525HP at the flywheel--you'd need to pump the fuel pressure up to 75psi to get 650fwHP out of the 42's; 105psi to get 650 to the wheels.
I assume you meant a Walbro 255lph pump, is it the standard or high pressure model?
I ask because the standard pressure model won't make 100psi. and the HP model only flows 32gal/h at 13.5V and 100psi; that's 192lb/h, only enough for 320fwHP or so (I ran the 255lph HP pump on my M55 Eaton '92 Miata, at 100psi fuel pressure to get 255rwHP at 18psi boost--a bunch in a 1800lb car).
72lb/h injectors at 40psi would get you up to the 650rwHP with some head-room (they'd be running 80% duty cycle). And the Walbro standard pressure pump can deliver 68gal/h at 40psi. That's 405lb/h, good for about 680HP at the flywheel...
You cans see that at 40 psi the HP model has only a 12lb/h advantage. Using the typical BSFC (Brake Specific Fuel Consumption) of 0.6lb/h for forced inductions applications the standard pump would max out at 408/0.6 = 680fwHP; the HP model at 700.
Note that these are both flywheel HP, and that they are "maxed out" capacities based on Walbro's specs. Using an 85% design ceiling they work out to and 575 and 595 flywheel HP respectively.
Using injectors larger than 72lb/h would add nothing as the pump would be flat out anyway.
Here is the formula for estimating fuel injector fwHP capacity:
BSFC for n/a is typically 0.5lb/HP, 0.6lb/HP for f/i.
And how to recalculate injector capacity as fuel pressure is changed:
09-16-2015 07:53 PM
09-10-2015 08:39 PM
