Brakes dragging and HORRIBLE gas mileage
So I lowered my car recently and when I took the front caliper off, it had 4 rubber rings inside of them. Two of them were beasiclly ripped. Is this bad? This applies to BOTH of the front calipers.
Another problem is that I can't spin both of the front wheels freely when the car is in the air. Are the brakes dragging? Again, this applies to both of the front wheels.
On a side note, I've been getting about 120 miles to the tank. I know it wasn't bad gas as I have now gone through 3 full tanks getting just about 120 to the tank. I've been taking it easy on the pedal too. Could this be a result of the brakes dragging?
I just changed the fuel filter with no improvement. Car has 30k ish miles on it too.
On a side note, I found this deserted road with a bunch of sharp turns and what not. So I was there for about 15 mins and driving the car pretty hard. When I was at WOT, the car just turned off. How could this be? The engine temp gauge was right in the middle and not at the "hot" level.
Cannot speak to why your car shut down, but your wheels should spin pretty freely when up in the air. There maybe an issue with wheel bearings, as if the brakes were rubbing this bad, they would turn to mush after 10~15 minutes of driving.
Take your car out for a 10 minute drive with minimal brake usage and lick your finger and touch your front rotors. They should not be hot, unless you just broke VERY hard prior to testing this way. I really doubt the brakes are an issue in this way, but you NEED to make sure! If bearings are too tight or somthing, then the area around the bearings would be VERY hot. I have not tested this area prior, but cannot imagine it as more than warm.
As for the rubber boots around the pots (pistons of calipers), they are best to be intact. They keep water/dust exposure to a minimum/zero and can cause seal failure upon new pad installation if you don't have them COMPLETLEY clean when pushing the pots back into calipers.
Jazzer
Jazzer
I think the term 'freely' means grab the wheel and spin... it will go for awhile.
I've seen a couple of calipers go bad, and lock down on the disc. If it is that, it's the source of your poor MPG.
Also, if you are having brake issues, I'd avoid going WOT around sharp corners on backroads. Seems like a good way to die.
^ exactomundo on my meaning of "freely"
If a caliper is sticking, the car will pull like a dog to that side of road and promptly pull BACK to the opposite side when you apply the brakes, due to heat-soak. If BOTH fronts are sticking, they would have to be EXACTLY the same amount, or it would STILL pull to the worst side.
Extremely doubtful that this is a braking issue.
Jazzer
Jazzer
2010 Blue Ball Award Recipient
Umm... If your pads were always ON the rotor, your mileage, brake life, braking distance, etc would be a joke.
