ram clutch burns easily
I just installed a new ram clutch with my hanlon built 3650, theres about 1000 miles on the clutch/pressure plate. if i allow the clutch to slip even a little bit i can smell it burning, my spec did not used to do this...if i blip the throttle as im releasing the clutch it will do it too. Why does the ram do this over the spec? anyone have this problem?
i had my flywheel resurfaced, it was the same one with the spec...everything is setup up properly, its my third time removing clutch/trans so im and never had a problem any other time...it doesnt do it all the time, just whenever i slip it by releasing it too slow and giving it more gas such as in reverse or making a uturn on the road from a stop
lincolnshibuya
12-08-2015 04:37 PM
junior04
09-28-2015 10:53 AM
