2000 mustang very low torque under 2000 RPM
Old 05-14-2011, 09:27 PM
pals911
pals911's Avatar
Default 2000 mustang very low torque under 2000 RPM
any ideas on how to fix this olny thing that has been done is a proformance tune and straight piped
pals911 is offline
Old 05-15-2011, 08:04 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
In what gear or gears is this noticeable?
cliffyk is offline
Old 05-16-2011, 05:51 PM
pals911
pals911's Avatar
all mostly first when i give it like 3/4 throttle it kicks a second time when it hits 1800 2000 rpm but also like in 5th when just crusing at like 45 it has little to no exel im not expicting alot but it like falls on its face if i try to exelerate when its under 1500 rpm
pals911 is offline
Old 05-16-2011, 07:09 PM
Rockwell28
Rockwell28's Avatar
How long has it been straight piped? Or did you Just get it str8 piped and tuned and you lost your low end right afterwards?
Rockwell28 is offline
Old 05-16-2011, 09:16 PM
BraMas
BraMas's Avatar
When you say "straight piped" do you mean that you don't have a Mid Pipe ie X or H? If no that is where your torque went
BraMas is offline
Old 05-16-2011, 09:19 PM
94Blk5.0
94Blk5.0's Avatar
It's not going to have a lot of pick up in higher gears at that speed, but how is the fuel filter? Those are often neglected, and you'd be surprised how much a dirty filter can affect performance.
94Blk5.0 is offline
Old 05-17-2011, 09:40 AM
pals911
pals911's Avatar
i use the term stright piped its probly not the proper term its still got the cats just mufflers chopped out and pipes welded in and its been stright piped for about 4 weeks it already had the problem before it was tuned
pals911 is offline
Old 05-17-2011, 01:36 PM
72MachOne99GT
2010 Blue Ball Award Recipient
72MachOne99GT's Avatar
are you sure this is a 'problem' or are you expecting the car to just get up and go at that low of rpms and it isnt?
I'll be honest, unless my car is in 1st or 2nd gear, punching it below 2200 yields little to no 'oomph'
As others said, check your fuel filter, air filter, and maf....
if the car is chugging or surging then you might have spark plug problems..
this was one of the first signs I had an improperly gapped plug (due to the plug stripping the threads and being struck by the piston)
72MachOne99GT is offline
Old 05-22-2011, 02:04 AM
pals911
pals911's Avatar
i need to check the fuel filter air filter is good and its probly just the fact that im not use to an overhead cam car all the v8 cars i have had have been single cam push rood motors and the torque starts out lower where in the stang under 1800rpm its a dog after it hits over that it breaks the tires loose and takes off like id expect
pals911 is offline
ShaneB26154
35
03-04-2021 04:05 AM
mmbrown
09-08-2015 01:29 AM
01blackgtconv
08-14-2015 04:50 PM
daytooday
08-11-2015 09:22 AM
01blackgtconv
08-10-2015 01:25 PM
Quick Reply: 2000 mustang very low torque under 2000 RPM
