Clutch Pedal Vibration
I recently had my clutch done with a new pilot bearing, throw out bearing and a Ram Stage III clutch kit. I also had the mechanic install a new clutch cable, steeda quadrant and three way adjuster. I am getting a seriouse clutch pedal vibration whether I am driving or sitting still, I can press the clutch a little and the vibration stops completely. But when the pedal is all the way out it vibrates terribly. any ideas on this????
02 GT, Steeda Tri-ax short throw, SCT Tuner, Steeda Underdrive Pulleys, BBK CAI, BBK 78MM Throttle body, BBK Long tubes, SLP X Pipe, FR 3.73 gears
How much free play does the pedal have (press on it with your hand until you feel the TOB start to press on the Belleville spring). It should be 1-1/4" to 1-1/2", if more the cable is too loose, if less it's too tight; use the firewall adjuster to set it properly.
junior04
09-28-2015 10:53 AM
