Is a SCT tuner worth it
I have just got a 97 GT vert. this puppy is in mint condition with 42000 miles on it. only mod is a Loudmouth catback that i just installed. i would like more power and have been debating getting a SCT tuner. will i feel the difference? is it worth it?
It's not a huge performance gain. It makes your throttle response a little quicker but you still need to get it because if anything ever goes wrong you can plug it in and get a code. With a code you can find out what the problem is and will save you a lot of time and money instead of a mechanic to tell you and possibly be wrong. You won't regret it.
If you plan on keeping and modding your car and the future it's probably worth it. If it were me I would put the money else where. You'll get more performance gains installing gears than a tuner..
All of the above posts are good. Soldier GT is very much on target.
Since you have a 5spd, the only real benefit you can get from a tuner at this point would be a 93oct tune. You wouldn't notice any difference.
Gears would be very good use of your mod dollars at this point, but then a tuner would be desired to correct the speedometer...
Now is the time to make a long term plan for the car, and decide what you want the car to do before you start with any mods.
GOOD LUCK!
GOOD LUCK!
