Question about hooking up a killswitch to your IAC....
#21
So I'm thinking the relay is under the drivers seat or in the fenderwall correct thats what I have been reading? So in the trunk I can cut the wire and install the kill switch then splice the wire to the kill switch wires correct? The two wires on the kill switch, one replaces the old wire to the switch then the old wire gets spliced in, the second kill switch wire goes where? I've done engine work and exhaust work and body work but total noob to electrical any advice would be great, thanks!
#22
pretend that the speaker it the inertia switch, and the pie is your kill switch, and the dashed lines the wires. cut one factory wire, then take one wire from the kill switch and connect it to one side of the cut wire, then take the other wire from the kill switch and connect it to the remaining cut wire. sorry about the crude pic am at work.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
