FUEL INJECTORS
FUEL INJECTORS
How much HP can each size fo fuel injector support? I am trying to figure out what size I am going to need and don't want to pick too small a size. I am leaning twords the #30 injectors. Here are my calculations (useing the info on RPM's website to calculate flow rate/hp for injector size) as to what each will support, am I correct?
#19 240hp
#24 305hp
#26 330hp
#30 384hp
#19 240hp
#24 305hp
#26 330hp
#30 384hp
RE: FUEL INJECTORS
I am going to be installing the P-51 intake with a set of fox lake stage 2 heads and VT stage 2 cams. And if the above # are correct then I am at the end of what my stock #19 injectors can handle. Car was dynoed at 243 rwhp
RE: FUEL INJECTORS
I have not checked to see if I have #24 stock, I thought they came with #19 injectors stock, but I may very well be wrong. Even if I do have #24 injectors how much hp can they support?
RE: FUEL INJECTORS
Also remember,
Must use with correctly calibrated mass air meter when upgrading to larger injectors, or your car will not run correctly !
For example: 24lb injectors must be used with a mass air meter calibrated for 24lb injectors.
RE: FUEL INJECTORS
ORIGINAL: DIVER8374
Hot street cam, needs 3.55+ gears. 2400+ stall. Intake, exhaust, computer and spring upgrade recommended. Agressive idle. RPM range 3000-6500+.
