Strange misfire problem
Old 06-19-2011, 12:57 PM
1998Slow 'Stang
1998Slow 'Stang's Avatar
Angry Strange misfire problem
I now have a '98 GT...that like to misfire at odd times. When I start in first and floor and go through the gears, its fine. But say if I'm cruising down the road at 50 MPH in 5th gear (car has what I believe to be 4.10's) its fine as well.......until you get in the gas hard. Then it misfires, repeatedly, enough that I know it's doing it, but not enough that it throws a code, so no CEL light no flashing, nothing. It seems to happen under load in higher gears around 2500 - 4000 RPM, then its fine. I just replaced the fuel filter as of an hour ago and it has relatively new wires. I'm going to mist the wires with water tonight after dark to see if they arc just to be sure, same with the coils, which I believe to be stock, however dont wanna replace em if its not the problem. Any ideas other than what I have already stated would be an awesome help. Thanks in advance.
1998Slow 'Stang is offline
Old 06-19-2011, 05:16 PM
Pest007
Pest007's Avatar
Subscribing to thread.... I have a 2002 GT doing the same thing, misfire only under load.... Idle is fine, but miss fires, and I have the coil packs..... Not sure what else could do it...
Pest007 is offline
Old 06-19-2011, 10:12 PM
1998Slow 'Stang
Are you sure you have the coil packs? I was under the impression that 96-98 ONLY had the packs of 4 attached to each head. I thought new edge had COP's
Glad, in a way, to hear that I'm not alone. The fuel filter did help a little bit. I misted the wires with water to try to get them to arc but no luck. That would have made it fairly simple. I'm going to start pulling spark plugs and checking gap and wear tomorrow morning when the engine is stone cold. If that turn up no luck I'm going to break down and put new coil packs in.
Old 06-21-2011, 09:31 PM
1998Slow 'Stang
For those who even noticed or cared about this thread, I fixed the problem! The driver side coil pack which I believe fires the the plug for cylinder #2 was barely sparking. With the car idling I could get the other to arc at more than 2 inches away.
However the terminal for cyl. #2 was just barely making a spark. So I did some coil pack swapping and fixed it. The car runs like a champ.....now I just need to get a new thermostat since my old one decided to play metal shredder and self destruct taking the rad. fan with it somehow.......
Anyway, to those who read this good luck fixing your misfire or helping someone fix theirs.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Omgitsa88Stang
10-05-2015 07:33 AM
bconboy
09-21-2015 12:52 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Strange misfire problem
