Degreeing stock cams - info needed ASAP
Old 06-27-2011, 10:50 PM
gthokiwi
gthokiwi's Avatar
Default Degreeing stock cams - info needed ASAP
Does anybody have the settings for degreeing stock cams on a Mach 1 4.6 4v?
Thanks
gthokiwi is offline
Old 06-29-2011, 04:11 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Do you mean installing the timing chains--if so here's the procedure.
"Degreeing" a cam is a whole different thing here in the States, it is the checking, verifying, and if possible adjusting the exact timing of the valve opening and closing. On our cars, with stock cams and without adjustable cam sprockets, it is an interesting but largely irrelevant exercise.
cliffyk is offline
Old 06-30-2011, 10:11 AM
dimebag
dimebag's Avatar
Irrelevant my ***..... Cam degree will make or break a car.... And the spec ford oks leaves room for decent gains
Why do u think some cars go 14.3 stock vs sone goin 13.7 stock?
dimebag is offline
Old 06-30-2011, 11:58 AM
SVTeeshirt
SVTeeshirt's Avatar
1.Cecil County is only 1250 feet and downhill.
2. Some people can't drive.
3. because racecar.
SVTeeshirt is offline
Old 06-30-2011, 01:16 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
I never said that "degreeing" cams was irrelevant. What I said was that since with the stock components there is no mechanism to adjust cam timing, going through the motions with the stock components is an "interesting but largely irrelevant exercise."
You need to improve your reading comprehension skills...
cliffyk is offline
Old 07-01-2011, 09:12 AM
dimebag
dimebag's Avatar
And u need to improve on your holier then thou and real life skills.... Get out from behind that computer and get ur hands dirty once in a while, its good for you
And I didnt just mean mine, at cecil....i meant in general..... Ive ran other ppls cars at cecil, and they went slower
It is a pita to do it w stock ****, but its doable, and worth it if your willing to put out the effort
dimebag is offline
Old 07-01-2011, 09:25 AM
Bmitchell373
Bmitchell373's Avatar
I would love to see someone degree a stock cam, with stock sprockets.
Bmitchell373 is offline
Old 07-01-2011, 09:39 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
You started the "attitude", I just finished it up...
And as Bmitchell373 said quite eloquently "I would love to see someone degree a stock cam, with stock sprockets."
cliffyk is offline
Old 07-01-2011, 09:51 AM
dimebag
dimebag's Avatar
Its very doable.... Id start with a matched pair, and get the file out....its not the "right" way, but its been done countless times, and does work
dimebag is offline
Old 07-01-2011, 10:17 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Umm, I'll just leave this here maybe it'll help
WhiteFoxGT is offline
Quick Reply: Degreeing stock cams - info needed ASAP
