sn95's PI swap
Old 07-26-2011, 06:28 PM
  #41
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
more progress finally got the other side finished up!!
few of the GM boys lending me a hand, waiting to see exactly how fast a ford can be (not a biggie, they're both into trucks and old school pushrod power (monte carlo SS' and 3rd gen Camaro's no LT/LS garbage). they had fun looking at the thing and trying to put the followers in rofl
and here it is all finished!!!
just waiting on the headers and starter to drop it in, then a few more odds and ends and it should be good to fire!!
BTW, thats all the motors going to have on it, no PS, no AC so the belt will be nice and short!
cant wait getting so close!!
sn95_331_GT_ yellow is offline
Old 08-03-2011, 07:59 PM
  #42
sn95_331_GT_ yellow
got the motor, clutch, flywheel, and trans bolted together and dropped in!!
had to bring the car back up to mass along with all my tools (long story). longtubes should be in tmrw hopefully and are going in this week/end, manual brak kit should be here next week along with the coils and wires, then all i need is to flash the comp for the 30#'s and see if it fires up!
ill post pics later when i load them
Old 08-05-2011, 06:40 PM
  #43
sn95_331_GT_ yellow
ill i have to say is **** the ever living **** out of longtubes im so fed up with these damn things... calling it a night and trying again tmrw i cant get the damn bolts to start wtf?!?!
Old 08-06-2011, 01:57 AM
  #44
JC316
JC316's Avatar
That is why I put the engine/tranny/LT combo in as one unit. Putting them on with the engine already in is a pain in the ***. You would probably be better off dropping the sub frame to get em in.
JC316 is offline
Old 08-06-2011, 08:22 AM
  #45
sn95_331_GT_ yellow
thats what i was think but my longtubes wrap around the steering shaft so FML...
Old 08-06-2011, 06:48 PM
  #46
JC316
JC316's Avatar
Mine did too, just take the shaft out, it's pretty easy. Just an 11MM bolt at the rack and a 10MM inside the car and it slides right out. Once everything is in, then you put it back.
JC316 is offline
Old 08-08-2011, 02:15 PM
  #47
amoosenamedhank
amoosenamedhank's Avatar
Until you have a tubular K-member this is the best way to do it IMO. Assemble the entire thing (engine/trans/longtubes) outside of the car, pull the steering shaft and install in one swift motion.
Or you can just buy a tubular K member and get the job down in about 45 minutes.
amoosenamedhank is offline
Old 08-08-2011, 03:30 PM
  #48
sn95_331_GT_ yellow
still couldnt get the damn bolts started let it sit for ab out 3 days...
pulled my head out of my *** (after i almost dropped kicked my cars the other day) moved the headers over a few inches, put the bolts in the heads, cut the heads off the bolts, put the gaskets on, then found some 8X1.25 bolts and voila problem solved...
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: sn95's PI swap
