whats the difference between dohc and sohc?
RE: whats the difference between dohc and sohc?
The SOHC which are in the GT's means single overhead cam and they have 2v's per cylinder (one intake, one exhaust). The mach and cobras have a DOHC engine which means dual overhead cams and it's also 4v's per cylinder (two intake, two exhaust). Whoever told you the SOHC's are better is wrong.
SOHC = Single Over Head Cam
DOHC = Dual Over Head Cam
1 engine takes 2 cam's the other takes 4?
If DOHC , usually 4 valves per cylinder, 4 valves x 8 cylinders = 32 valves total
If SOHC , usually 2 valves per cylinder. 2 valves x 8 cylinders = 16 valves total
breaking
10-02-2015 01:27 PM
mrappe
09-26-2015 10:16 AM
mungodrums
Suspension
09-24-2015 10:12 PM
