cylinder misfire problem.. C.O.P.S (Ignition Coils) and sparkplugs
code being thrown code p0354rimary/sec. ignition coil fault D
I went ahead and changed out the cop on number 4/D and all new 8 spark plugs .50 gapped motorcraft platinum oems
still getting the code thrown, and a seeming misfire..... what now???? really a fuel injector causing this ?? or... Cliffyk and tech gurus anything you can throw my way thank you! car motor is stock! -Dev1
Here is what the shop manual says about P0354, work the list from the top down.
Also, as Bmitchell' said the cam/crank position sensors can go bad and create EMI and RFI that messes with the PCM's mind--there is no reliable way the test them with typical tools, so swap 'em out--do the crank sensor first...
so for tmrw what tests should I do.... crank sensor swap? fuse tests?
I really don't know what to do next I want the gt running well! gt stuttered early when i had it idling and sounded normal but then lost it and when back to the boaty hesitant bog its making now....THANKS AGAIN!
can someone verify for me the cylinder order.. cyl. 4 is back passenger side if facing motor right?? which is also known as D. I couldnt find a diagram with letters like a b c d... only diagrams with 1 2 3 4 etc..
