OE Parts?? Intake Tube?
Old 07-18-2011, 06:58 PM
Justin00GT
Justin00GT's Avatar
Default OE Parts?? Intake Tube?
So where can I find a place like Autohausaz.com for Fords? They sell Ford stuff, but not in the quantities they do BMW stuff (what I used to order from them for).
I've searched here and all the places listed either sell more mods than maintenance stuff, or their sites are set up terribly.
I need a few things, but cannot for the life of me (even via Google) find a place to get the stock intake rubber tube. The long one. Looking to re-do the intake tube, PCV valve, and crankcase breather hose/vac hose fittings.
Justin00GT is offline
Old 07-18-2011, 07:09 PM
lizzyfan
Underboss
lizzyfan's Avatar
Try Napa or Rockauto
lizzyfan is offline
Old 07-18-2011, 10:35 PM
trailor
trailor's Avatar
why would you want that and not an aftermarket tube?? if you're really obssesed with stock, i would personally recommend a junkyard or ebay..
trailor is offline
Old 07-18-2011, 11:41 PM
SVTeeshirt
SVTeeshirt's Avatar
What you SHOULD do is pick up a stock intake tube from one of these kids who thinks their bbk intake is actually doing something.
SVTeeshirt is offline
Old 07-19-2011, 01:31 PM
Z28KLR
Z28KLR's Avatar
Latemodelrestoration.com has the stock intake tube I believe.
Z28KLR is offline
Old 07-19-2011, 02:35 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Nearly all aftermarket intakes offer no improvement over the OEM unit, many will reduce power at some RPM ranges.
I have seen several of the cheap assemblies purchased on eBay that were made with 3" tubing! How one feels that using 3" (76.2mm) ID tubing with an 80mm MAF constitutes an "enhancement" escapes me...
cliffyk is offline
Old 07-19-2011, 03:31 PM
Justin00GT
Justin00GT's Avatar
Thanks, RockAuto had a nice site. Didn't locate the stock rubber intake inlet, but I might try calling to see if they stock it.
Well I don't want another used one if I stay with the stock piece. I just want a nice new one with soft rubber. And clean on the inside. My whole intake system is a mess from a failed PCV valve, oil everywhere.
I am not against a aftermarket tube, it looks like it would be cheaper and look better, but as stated below, I've heard it only adds to heat sink and doesn't add any power.
With that said, I could heat wrap one, do you know of any place that sells just the tube? I already have a air hog filter.
Yeah, if it was from a low mile, newer GT, that would be a good idea.
Thanks!
Thank you. I just want to ensure I get a piece that doesn't take away power, that would be a silly idea.
Old 07-19-2011, 04:05 PM
trailor
trailor's Avatar
certain models, such as K&N and JLT, use hard plastic or PVC piping, which would not increase heat soak, and may actually cause temps to be slightly cooler. JLT has a very large pipe (biggest in the market that i've found thus far), which, if intending to stay mostly stock, probably won't be necessary, and can hurt you to some degree as cliffy stated. if, however, you plan on increasing airflow in the intake manifold and heads, that may be a better option. but, and correct me if i'm wrong, i think K&N's is pretty close to stock size.
trailor is offline
Old 07-19-2011, 04:07 PM
Justin00GT
Justin00GT's Avatar
Good info, thanks. Know any solid places for the K&N set up?
Old 07-19-2011, 04:22 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The JLT, and the K&N, are perhaps the only units that stand any chance of working better than the OEM intake--as they are both designed with a clear understanding of what goes on in an intake tube¹.
The JLT's are nicely made, however K&N's construction and choice of materials have never impressed me.
¹ - The air flow in the intake tube is not a continuous stream, but rather a series of pulses (with negative pressure heads, near ambient pressure bodies, and positive pressure tails) whose frequency is proportional to engine speed. The shape of the tube can be designed to enhance this flow at certain frequencies and provide for better aspiration--both JLT's and K&N's (and Ford's) engineers know this and design accordingly.
All of the others that are just straight-walled pieces of tubing do nothing to enhance the flow dynamics; that is why they can actually rob power at certain engine speeds and loads.
cliffyk is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Granatelli Sales
01-20-2020 12:34 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
cbird1177711
09-03-2015 08:43 PM
Steve@CJPP
CJ Pony Parts
09-03-2015 11:43 AM
Quick Reply: OE Parts?? Intake Tube?
