Charger and window question
Old 07-20-2011, 09:32 PM
shortguy74301
shortguy74301's Avatar
Default Charger and window question
On my 04 gt my driver side power window works intermittently one day it will work one day it won't any recommendations ?
Also which is better hellion turbo charger a super charger or procharger
shortguy74301 is offline
Old 07-21-2011, 05:14 AM
Blackvenom01
Blackvenom01's Avatar
might be a short in the line the motor might be going out...a way can narrow it to the motor is ive seen on a couple cars that if you push down on the window like load the motor it can make it work again..that might be completely useless but i had to do it to one of my cars which told me it was motor
as far as your last question you will get tons of mixed responses...all are good...gotta figure out what you wanna do with your car then do some searches and see the best set up...such as daily driver, drag car, weekend warrior, street and strip.
turbo builds boost using exhaust cant reach some insane power numbers
supercharger(whipple, KB, eaton) has constant boost soon as you hit the gas and is belt driven by the crank
procharger is a belt driven turbo which builds boost..and the cheaper of all the set ups
Blackvenom01 is offline
Tivo304
08-28-2023 12:19 PM
GimpyHSHS
09-18-2015 12:27 PM
04stangman
09-17-2015 01:45 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Charger and window question
