2nd gear grinding on 96 GT
2nd gear will grind on my 96 GT but only when shifting at high rpms like around 4500+. You can get it up to 5K in 1st, let go of gas, push the clutch in all the way, shift into 2nd and without even engaging the clutch its grinding. As soon as you try to put it in 2nd it grinding. Is this a tell tale sign of a bad syncro? Its happening when not even power shifting or anything. Just thought someone could give me some answers. Than
ks.
ks.
RE: 2nd gear grinding on 96 GT
Hey. Yeah I had the exact same problem you're describing. Granted, this is with a T-45, but the same symtoms. I took it to a tranny shop and they wanted to charge me like $1500 for a rebuild. So I said screw it and just bought a T-56 from SHM.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
