Pi Swap
#21
So what's the scoop on the ptv clearance issue? can I run comp stage II cams in pi heads with a nPi block? right now I've got pi cams in it(BTW, didn't take front cover off to do the job, I used the Anderson tool and it worked great). will comps give me a good boost in hp compared to pi's? thanks. really appreciate all the input.
the only reason im running those is because i got the cams, brand new 191 lb srpings, and BBK fpr and AC delete (that i didnt end up using) for $300
my next thing is gonna be a 5.0 stroker, MHS stage 3 heads, stage 2 turbo cams, and an on3performance 76mm turbo, the longtubes COMPLETELY turned me off the running a blower, so its either that, or just build a damn DART 363 pushrod motor and make 500rwhp N/A all day long...
Matt's 95 Stang
10-05-2015 07:16 AM
