Mach 1 qurter mile time
RE: Mach 1 qurter mile time
5.0 Magazine did a comparison a while back with a Mach1, Bullitt, and 01 Cobra. They had a great day: Mach 1 did a 13.1, the Bullitt ran a 13.5, and the Cobra was a little slower because it had lowering springs that were messing up the weight distribution out of the hole. The Mach also has a better torque curve than the 32 valve engine in the older Cobras. But yeah, with a good driver, all these cars are capable of running the typical numbers.
ORIGINAL: Dave2000GT
I personally do not believe this number at all.
14.5 at best for a stock 99-04 GT.
ORIGINAL: silvergt
i know what ur saying but is a stock best time like the 99-04 gt is 14.1
ORIGINAL: silvergt
12-Second Club
01} JTCOBRA-----(MI) Black- 5spd---1.672, 12.019 @ 113.65 CDEG3JKMWXY
02} brian----------(MI) Blue-- 5spd---1.635, 12.294 @ 110.57 CEG5JKMSXY ____________________________________________
03} cobralsc------(TX) Yellow 5spd---1.979, 13.113 @ 105.31 E
04} 69Mach03----(DE) Gray-- Auto---1.969, 13.125 @ 106.04 J
05} Mach1driver-(CA) Red--- 5spd---1.850, 13.167 @ 104.21 AE
06} Black98GT---(DE) Red--- 5spd---2.062, 13.190 @ 105.57 BO
07} cmylxgo------(MI) Red--- Auto---2.089, 13.201 @ 105.58 ABG3JKM
08} funk-----------(TX) Blue-- 5spd---1.928, 13.216 @ 104.10 ABEJ
09} Blown86GT---(LA) Blue-- 5spd---2.054, 13.243 @ 106.53 E
10} rguy3---------(FL) Red--- 5spd---2.038, 13.262 @ 105.78 *
11} N20D5OH-----(FL) Blue-- 5spd---1.950, 13.264 @ 104.10 *
12} Tomcat427---(TX) Blue-- 5spd---2.095, 13.337 @ 107.02 KG1N
13} CMEmach1---(PA) Blue-- 5spd---2.169, 13.362 @ 106.08 BJO
14} rjw158-------(MI) Red--- 5spd---2.064, 13.43_ @ 105.63 ACDH3INO
15} killer55-------(OK) Red--- 5spd---2.103, 13.528 @ 102.71 *
16} Zate-----------(FL) Gray-- 5spd---2.061, 13.576 @ 104.01 B
17} TX MACH 1---(TX) Blue-- 5spd---2.134, 13.606 @ 101.80 *
18} ITS BACK-----(MO) Red-- 5spd---2.079, 13.628 @ 102.03 BO
19} Brain----------(TX) Gray-- 5spd---2.068, 13.634 @ 102.38 O
20} RossG--------(TX) White- 5spd---2.39_, 13.86_ @ 103.37 *
21} MachMonster(CO) Gray-- 5spd---2.375, 14.710 @ 96.69 *
Magazine/Media Tested
Paul Svinicki--5.0/SF Apr03 (MI) Black- 5spd--- n / a, 11.98_ @ 112.52 ABDFG3H2JKMORSTVWX
Evan Smith--MM/FF Mar03 (NJ) Gray-- 5spd--- 2.07, 13.135 @ 105.51 *
Paul Svinicki--5.0/SF Apr03 (MI) Black- 5spd--- n / a, 13.29_ @ 105.13 O
Jack Keebler----M/T Dec02 (n/a) Red-- 5spd--- n / a, 13.80_ @ 102.5_ *
Tom Wilson--5.0/SF Apr03 (NV) Yellow 5spd--- n / a, 13.82_ @ 101.01 *
MODS LEGEND:
*= Factory Stock
A= Air Silencer Removed
B= Filter Only (Like K&N)
C= Power Pipe / Cold Air Kit
D= Weight Reduction (Tire,Jack,Seat,Sway Bar,etc)
E= Drag Radials
F= Slicks
G#= Gears (G7=3.73, G9=3.90, G1=4.10, G3=4.30, G5=4.56)
H#= Headers (H1=Shorties, H2=Mid Length, H3=Long Tubes)
I= X or H pipe with Cats
J= X or H pipe w/out Cats (aka: off road)
K= Exhaust Cat Back
L= Mufflers w/stock pipes
M= Chip
N= Aluminum Driveshaft
O= Shifter
P= Mass Air Flow
Q= Throttle Body
R= Ported Intake/Spacer
S= Underdrive Pulley(s)
T= A/C Bypass Kit
U= Race Fuel
V= 31 Spline Axles
W= Eaton Posi
X= Suspension
Y= Shocks
MODS LEGEND:
*= Factory Stock
E= Drag Radials
F= Slicks
K= Exhaust Cat Back
M= Chip
O= Shifter
P= Mass Air Flow
Q= Throttle Body
T= A/C Bypass Kit
U= Race Fuel
V= 31 Spline Axles
W= Eaton Posi
X= Suspension
Y= Shocks
ORIGINAL: Dan04COBRA
Witnessed several 13.8* runs of a 100% stock 04 GT with tire pressure adjustments only.
ORIGINAL: silvergt
