Stiff Clutch
Clutch should feel soft and easy to push in. If you have to give quit bit of forsce and muscle from your calf the clutch is going out. Yes its hard to tell cause the car still goes as normal cause my clutch still moved the car like the semi I drive. So since getting a new clutch the vehicle will engage mutch faster a top of pedal release. You'll know when its worn out by the time mine was replaced it was an inch off the flore when engaged. Just to get the clutch into gear I had to remove the floor mat a smash the clutch into the ground to shift it from gear to gear. When I had the mechanic at precision tunes replaced the clutch he showed it to me it was a goner.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
