Sound like an intake gasket?
Old 09-21-2011, 08:38 PM
97stanger
97stanger's Avatar
Default Sound like an intake gasket?
Well, I brought my car to a show last weekend and it just didnt have the power it should, it also seemed to be popping out of the exhaust. So, first instinct was to check the plugs. I go to check the driver side front plug and there is coolant completely up to the top of the plug in the chamber. I checked all of the other plugs and the passenger side was completely fine, and 3 of the 4 plugs on the driver side were completely flooded with coolant. My first thought was that I blew a head gasket. My dad and I checked it out some more...we didnt notice any smoke coming from the exhaust, we dropped the oil and there was no separation from oil with any other fluid...called around and my tuner thinks I just blew an intake gasket. He said that a blown head gasket wouldnt have enough pressure to fill the entire chamber with coolant.
Now the only problem is taking two plugs out, we accidentally pulled out two of the timeserts with the plugs. We are going to re-tap the heads just to be safe, but it didnt seem to cause any harm. I'm going to start with replacing the intake gasket and hopefully thats all it is....what do ya guys think?
97stanger is offline
Old 09-22-2011, 05:16 AM
uberstang1
Chupacabra
uberstang1's Avatar
How did the timserts come out, I thought once those puppies were in they are in.
uberstang1 is offline
Old 09-22-2011, 05:23 AM
Blackvenom01
Blackvenom01's Avatar
well i agree with your tuner that it is the intake! def not the head gasket
Blackvenom01 is offline
Old 09-22-2011, 05:24 AM
Blackvenom01
its prolly cracked the intake manifold rather then gasket but look it over good when you pull it
Old 09-22-2011, 05:41 AM
97stanger
97stanger's Avatar
that would really suck if it did, but I'll inspect the intake when its off. due to it being ported i guess theres always a possibility of it cracking. Well, the dummie I am never put antiseize on the plugs so it pulled two of the timeserts out. I bought some JB weld for the two timeserts, and this time around I'll put antiseize on the plugs.
Old 09-22-2011, 05:45 AM
uberstang1
Chupacabra
uberstang1's Avatar
Alot of people give mixed reaction on the antiseize thing, i guess with inserts its def a good idea, but I don't put it on my plugs either.
Old 09-22-2011, 06:32 AM
97stanger
97stanger's Avatar
yeah I didnt originally, but was told I should have. It makes sense because the plugs were in there GOOD, so hopefully there isnt any crazy damage to heads, thats all I'm really concerned about. An intake can be had for cheap
mtgldr
02-03-2024 09:00 PM
Nick Oliver
10-17-2018 04:22 AM
2007StangV6
01-28-2016 06:09 PM
04stangman
09-17-2015 01:45 PM
Quick Reply: Sound like an intake gasket?
