New clutch, 1st gear grind - MustangForums.com
Old 10-09-2011, 11:30 AM
Donnie's GTS
Donnie's GTS's Avatar
Default New clutch, 1st gear grind
So two weeks ago I had a new clutch installed (stock ford). Put about 440 miles on it without any problems. Now I have a grind going into first gear, not all the time, and can be cured by shifting into second, then back up to first. If I am rolling (5mph or <) or dead stop, and go from neutral to 1 it grinds in. So I had the trans fluid swapped to ford spec and, its still grinding. Would this be related to the new clutch?
Donnie's GTS is offline
Old 10-09-2011, 06:48 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
If you still have the stock semi-automatic adjusting plastic quadrant/pawl then follow the procedure here to adjust the cable--if not and you an after market quadrant and firewall adjuster or adjustable cable, then how much free play does the pedal have?
cliffyk is offline
Old 10-09-2011, 08:54 PM
Donnie's GTS
I have the stock quadrant and cable still. thanks for the info.
Old 10-10-2011, 12:38 AM
Repzard
Repzard's Avatar
Cliffy ..Does this method also take slack out of cable if there is too much play over spec?
I understand how the system works..thanks to this info you supplied
Repzard is offline
Old 10-10-2011, 10:46 PM
Donnie's GTS
just found something else, 1st is the only gear that will grind when trying to go into gear without the clutch using the clutch. Isnt there something that stops the trans from doing this?
Old 10-10-2011, 10:52 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Yes, it allows the cable, release lever and TOB to re-position themselves...
cliffyk is offline
Old 10-10-2011, 10:56 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
If you are asking if there is some sort of interlock to prevent the transmission from being shifted into 1st (or any gear) with the clutch pedal NOT pushed in then the answer is no, there is no such interlock--the driver is supposed to know better than to try to do that...
cliffyk is offline
Old 10-11-2011, 09:29 AM
caaraa
caaraa is offline
Old 10-11-2011, 02:55 PM
Donnie's GTS
Ok thanks.
jwog666
01-07-2018 07:16 AM
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
Quick Reply: New clutch, 1st gear grind
Featured Sponsors
