Rod bearing replacement with motor in car?
Just curious if anyone has replaced the rod bearings with the motor in the car. I know I have to lift the motor up about 4 inches to remove the pan so that it clears the pick up tube. I know everyone will ask lol so I am replacing the bearings (as long as the crank isn't damaged) because I am getting a slight knock from the lower end. I am so sick of the problems with this car and I have so much money in it that I want to try to replace the bearings before putting another motor in it.
I have my own shop so equipment isn't an issue just wondering if i should pull the motor or try to do it in the car. It kind of sucks because I just had the transmission out to replace the clutch a few weeks ago. I replaced the bearings on my 95 SHO with the motor in the car without much hassle so I am hoping the 4.6 won't be either.
I would only do it in the car as an emergency repair on one bearing. It is really tough and you'll never be able to inspect the journals with confidence lying on your back.
Pull the motor and go through it properly now. It only gets more expensive the longer you wait.
On the way back home, we lost all oil pressure, so he stopped again, drained all the oil and filled the pan with STP. It git us home and another 1000 miles before he yarded it. But that was dicey. Only in an emergency...
Jskeezy84
09-08-2015 01:40 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
