0-60 times w/ 4.10 gear
RE: 0-60 times w/ 4.10 gear
Why would you want your 0-60 mph as a point of comparison on your mods. I think you should go for something like a 60's, 1/8's and 1/4 mile times. Those would be a lot easier to give you and estimate from the peoplehere in this forum.
About howmuch faster you've gotten with the new gears and the tuner, not always that upgrade the gears you will necesary go faster. As a matter of fact if you got street tire it'd be harder for you to hook up therefre making you 60' and your 1/4 mile times worse.
I'm sorry I wasnt able to help with the 0-60 mph times.
Good luck.
Good luck.
I had a 4.10 in my 88, It was almost a waste because first gear winds out and tour barely moving, and you have almost no top end. Plus, at highway speeds for long periods she used to get hot due to higher rpms. I think a 3.73 is a better choice. Hope this is helpful.
It's been proven time and time again that 3.73's are an extremely poor choice for a NA 96-04 GT.
Please look in our sections gear thread up in the stickies.
With 4.10's, your minor exhaust work and decent traction, you will def. see a 13.6-13.7* if you can shift & have the right conditions, that's considering when you were stock that you were capable of clicking off an extremely low 14. But a majority of your drivers can't do that, so you could expect to run anywhere from 14.5-14.0, even with the gears.
jwog666
12-27-2021 08:09 PM
musnicki
09-23-2015 07:11 AM
ccdguy
09-19-2015 05:20 PM
