How do I hit 600rwhp?
#21
It just seems to me that the only reason the power should fall off is if the blower can no longer feed enough air at that rpm
Do you have a log of the boost during the run?
Does it flatline or drop at that point.
I feel like your tuner should be able to log boost, timing, etc and figure out whats going on here. lol
You should bring that thing to my boy matt in delaware, he will fix you up
#22
thanks the replies guys.
I'm currently running 93 octane, but as I said I have a meth setup with 50/50 mixture that I should be getting tuned here soon.
My plugs are gapped at 26-28 also justin, no spark blowout as I also have timeserts.
Justin, does your tuner tune a lot of meth setups? I'm going to hit you up on facebook for some info
#24
unfortunately no track times, I recently just finished getting it tuned and before that had a blown rear. After talking to yet another tuner who doesnt want to tune my car on meth...I have decided to take the meth off. I have an E85 station 20 minutes from me, already have the fuel system to support E85...so I think this winter i'm going to fill up with E85 and go for a tune and see how the car responds
#27
#28
#29
Its almost like running race gas all the time so you can advance timing and it has a really good cooling effect in the combustion chamber
#30
The guy I bought my V2 SQ off of traded up to a YSI and is currently sitting at 673 RWHP on pump gas with one can of Torco additive. Here is his current set up so it can be done.
Motor:
.020” 4.6
Cobra crank
Manley Rods
Ross pistons (-18cc)
Foxlake CNC ported heads (Ferrea Valves, Manley Nextek Springs)
Foxlake custom cams
ARP head and main studs
Moroso oil pan and Canton Windage tray
Edelbrock Intake
Cobra throttle body*
Home made upper intake *
Fuel System:
Twin GT pumps*
Dual FPDM*
8an feed line*
Edelbrock fuel rails
60lb injectors
Exhaust:
Pypes T304 SS long tube headers *
SS VRS catted x-pipe
Magnaflow cat-back
SLP double wall tips
Drive train:
TR3650 5-speed
Center Force dual friction cluth
Center Force pressure plate
Cobra aluminum flywheel
B&M short row shifter
94-98 rearend housing (1.5 narrower)
31 spline axles (Moser)
TA cover
4:10 gears
Power adder:
Vortech YSI*
8 Ribbed drive
2.95 compressor pulley
7.5 ATI balancer*
3” piping
Treadstone A/A intercooler 4.5” thick
Mondo bypass valve
97-99 3 bolt front cover
4” intake with 12” air cleaner
Motor:
.020” 4.6
Cobra crank
Manley Rods
Foxlake custom cams
Edelbrock Intake
Fuel System:
Twin GT pumps*
Dual FPDM*
8an feed line*
60lb injectors
Exhaust:
Magnaflow cat-back
Drive train:
TR3650 5-speed
TA cover
4:10 gears
Power adder:
Vortech YSI*
8 Ribbed drive
7.5 ATI balancer*
3” piping
Mondo bypass valve
