How f**ked is my car? ( video )
Hey guys i was taking a nice Christmas highway cruise (topped out around 130) anyways as i get off the highway i can feel my shifter just shaking like crazy and vibrating tons, my car is making ticking sounds you can hear towards the end of the video, the car is also producing small amounts of smoke.
(checked oil, and turns out it burnt up around 3/4 of a quart, added more, still running the same ofc)
Possible problem causing scenarios:
1. Changed oil, (may be just a tad too much oil in vehicle)
2. Swapped spark plugs (could not be gapped correctly/installed poorly) (platinum plugs)
3. About a half a bottle low of transmission fluid (another bottle in mail) <- doubtful
http://www.youtube.com/watch?v=UUkyr...ature=youtu.be
mods. 3.73's cai/throttle body/plenum spacer short throw shifter, steeda udp.
borla catbacks.
Thank you very much you guys, =[ shame to see my mustang like this, would be cool if anyone here could offer me a quick diagnosis, happy Holidays
borla catbacks.
Pull your oil dipstick and look for a light brown and creamy consistency. That would indicate water getting into the oil. White smoke out the tailpipe indicates water in the combustion chamber. These would point to a bad head gasket.
Check all of your spark plugs and coil connections. One or more misfiring would make the motor run rough and shake. That would not cause white smoke though. However, since you recently changed plugs, I would make sure none of them are messed up. Also, double check that you installed the correct length plugs. Plugs that are too long could create a real problem if they were the wrong plugs. Be VERY careful about torque when you are installing plugs.
Keep us informed of what you find as you investigate further.
GOOD LUCK!!!
GOOD LUCK!!!
