Working with timing chain and I need help.
Old 01-08-2012, 09:03 PM
Mustangdroid
Mustangdroid's Avatar
Default Working with timing chain and I need help.
So my friend that works at a ford dealership is helping me change it and we found out that the tensioners were so badly worn out that the timing chain was eating the dowel pin where the tensioner goes in. The chain ate over half of the dowel pin and he said that it was pretty bad and he didn't know what to do. So he called I think he said his manager and told him about that and the manager said to keep going. I ask him if the pin can be replaced and he said no, that it was part of the block. We stopped and called it a day. My question is should we still keep going in fixing the car or just get a new motor? is the dowel pin really part of the block or it can be taken out? please help because I'm in a deep hole right now and I don't know what to do. Another thing is that I dont have the money to get another motor so it will sit there for months until I get the money. Thanks for reading and hopefully ya can help.
Mustangdroid is offline
Old 01-09-2012, 07:27 AM
1998Slow 'Stang
1998Slow 'Stang's Avatar
If the car is the '05 in your description, you would probably get much better help in the 2005-2012 section.
Our dowel pins can either be pressed in or threaded, and either way removable. Could be different on the '05 though.
1998Slow 'Stang is offline
uberstang1
Chupacabra
uberstang1's Avatar
Send me a pic i havent been under a timing cover in awhile, bu all the dowel pins should be replaceable.
uberstang1 is offline
Old 01-09-2012, 07:42 AM
Mustangdroid
I'm sorry about that. It's a 2002 Mustang GT.
Old 01-09-2012, 07:52 AM
02GTman
02GTman's Avatar
First mistake was asking someone from a stealership.
02GTman is offline
Old 01-09-2012, 08:00 AM
1998Slow 'Stang
No problem, in that case.......Good luck man!
^ +1
Old 01-09-2012, 08:47 AM
Mustangdroid
Old 01-09-2012, 08:53 AM
Mustangdroid
The lines go straight to the dowel pins.
Old 01-09-2012, 01:41 PM
JC316
JC316's Avatar
Those are replaceable and yes, they need replacing. You don't want to screw with the timing system on these cars.
JC316 is offline
Old 01-09-2012, 02:34 PM
Mustangdroid
Sweet is hard to get them out? Any special tools needed? Where can i get more pins?
Quick Reply: Working with timing chain and I need help.
