Sway Bar
RE: Sway Bar
I believe that removing it allows the front end to rise and therefore transfer more weight to the rear end, providing better traction. However, if you drive on the street, you will notice a definite change in handling.
RE: Sway Bar
My buddy has a Mach 1 without the fromt sway bar. He said it takes some getting used to, but eventually it will feel normal. Ive rode in it and it feels no different other than the front lifs better when you take off.
RE: Sway Bar
jdaniel,
I installed my springs a couple of weeks ago, but the front is still sitting at the stock height. If I replace the end links with shorter versions, do you think that will help? I know $hit about lowering springs and I'm upset that my 2 inch drop was 1 inch in the rear and 0 in the front. (My prothane isolators account for 1/2" I suspect).
09-16-2015 07:53 PM
