To Threadsert or not
Ok so this past week I blew a plug out of the head of my 00 gt. I got a kit to fix it. Today I go to fix it and use the first tap to clean out the existing threads, I packed it full of grease to catch the shavings and I did get quite a bit of shavings. I clean out the threads and tried the spark plug in it. Went right in with no issues and tightened down tight with no loose feeling like you know when the threads are getting ready to let go.
I put her all back together after running just a tap through the existing hole. Runs great, no more tick, and I did a couple of 5500 rpm pulls too and it stayed together.
So should I leave it till it blows again, take it out and maybe put on some blue threadlocker on the plug to help hold it in or just do the threadsert cause I will eventually need it. This is my 6th vehicle that has had a 4.6 in it, and I have always known about the spark plug problem in them but haven't had to deal with it till my current mustang.
Thanks
Zack
Thanks
Zack
since youve threadserted it you should have no issues, my old 2000 had to have one and i beat the tar out of it for 20k+ miles after that and it never missed a beat. i wouldnt recomend putting thread lock on your spark plugs, use never seize. the problem comes from the plugs seizing up in there and eating at that threads as it vibrates it. never seize the threads on the new plug and forget it.
Thanks
Zack
