Aeroforce wide band issues
I've had an aeroforce scan interceptor installed for a little while now and just got around to messing with the wideband so I can put it on the display but after following the directions my wideband stays stuck at 10.0 and doesn't fluctuate at all. Has anyone had this issue before and know how to fix it? I'm getting a new Livernois shortblock installed and the shop is going to dyno it tomorrow. Anyones help would be greatly appreciated!
Not me, I don't like digital gauges.
In part because I am a geezer, but also because you have to read the number to make sense of it. With an analog gauge a quick look at the needle position will often be all you need, and also indicator ballistics and range of movement of an analog gauge can provide a ton of information that is not readily visible, if at all, with a digital readout.
They are cheaper to make than mechanical and electro-mechanical gauges...
lincolnshibuya
12-08-2015 04:37 PM
