Code 1450 help?
01 GT keeps throwing a code 1450. I replaced the EVAP purge solenoid and checked for kinks in the hoses but found nothing. Gas cap is also new, I tried 2 of those actually just to make sure. Also and I believe this is relevant to the code, when I put gas in it, it will stop the pump like it's full of gas when it is almost empty. It's to the point where I hate putting gas in it.
Have you checked the filler tube to the tank? I have read where it rusts under the plastic sleeve and can cause issue. Shot in the dark but worth a look maybe.
Originally Posted by stevednmc
(Post 7814754)
Here are the possible causes for P1450, from the shop manual. Typically they are listed in decreasing order of likelihood...
