2000 mustang GT not starting
Hi everyone
My car is not starting; I was driving it fine on Friday all day and then I went to turn it on today (Sunday) and it wont start. I thought it was a battery problem so I tried charging it with my battery charger, but the same thing happened. It turns on but shuts off immediately. I tried turning it on and holding onto the gas and it revs but shuts off instantly again. I had this happen on my old mustang and it was because the cold air intake sensor fell out. I check the sensors on it and it looks fine... I'm stumped?! What could be causing this?
I have the OBD code reader on me but I can't find the plugin anywhere...usually its below the steering wheel. Anyone know where it is? Or can provide a picture because I can't find it anywhere!!
I found it!! Thanks....after ripping out the passenger side panels and not finding anything...I was on the wrong side the whole time lol.
I plugged it in and turn the key to accessory but its saying 0 error codes..am I supposed to try and turn the car on?
If the check engine light is off, then you probably won't through any codes.
When you turn on the car to accessory, can you hear the fuel pump turn on? How long has it been since you've changed the fuel filter (could be clogged, and it's very cheap/simple to swap a new one to check)?
